timing for 73 390 4 bbl
Old Dec 17, 2003 | 03:48 PM
MTZBoeger's Avatar
MTZBoeger
can"t seem to find the right timing?
Old Dec 17, 2003 | 06:21 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Dec 17, 2003 | 06:34 PM
Ratsmoker's Avatar
Ratsmoker
Set it at 12BTDC with the vacuum hose removed from the distributor and plugged.
Old Dec 17, 2003 | 11:36 PM
biz4two's Avatar
biz4two
You might want to start at 8 BTDC and work your way up to 12 or 14 BTDC. When you start to hear it "ping"...then back it down to the previous set timing #.
Remember #1 needs to be at TDC on the compression stroke. Also make sure your distrib is pointing to #1 on the cap and is fully seated into the manifold/block.
If the cap, rotor, plugs, and wires are old...replace them. That certainly will play a role in timing performance.
Good luck!
