gas mileage
Old Dec 17, 2003 | 08:48 AM
rodbeed's Avatar
rodbeed
gas mileage
i have a 96 f150.had the intake manifold gasket replaced and mileage has gotten worse.what can i check?
Old Dec 17, 2003 | 10:34 AM
blu's Avatar
blu
Start by pulling the codes.
Old Dec 17, 2003 | 10:52 AM
Argo's Avatar
Argo
As previously suggested, check for codes. Also check for vaccum leaks. Especially check to see that the vaccum line to the fuel pressure regulator is attached. If not hooked up, it can cause an increase in fuel consumption and NOT set a trouble code. Places to check for vaccum leaks would be around the runners, all vaccum hoses, and at the injectors. Lastly, if your engine had a manifold replacement due to coolant consumption, replace the O2 sensors, even if no code is set for them. The silicates in conventional coolants will contaminate an O2 sensor and make it's readings ineffective, usually resulting in a false lean signal to the computer, causing the computer to increase the injector duty cycle to add additional fuel to balance out the percieved lean condition.
Dave
Old Dec 17, 2003 | 11:46 AM
rodbeed's Avatar
rodbeed
gas mileage
do i pull codes even if engine light isnt on?
Old Dec 17, 2003 | 12:18 PM
blu's Avatar
blu
Yep pull the codes even if the engine light is not on.
Old Dec 17, 2003 | 05:56 PM
acerockola77's Avatar
acerockola77
What engine do you have, and what mileage are you getting?
Old Dec 18, 2003 | 07:39 AM
rodbeed's Avatar
rodbeed
i have a 4.9l 300 standard 5 speed.was getting around 20 mpg,but since i had the intake manifold gasket replaced it dropped to around 15 mpg
Old Dec 18, 2003 | 10:20 AM
mrak's Avatar
mrak
Good way to check for vac leaks, if you need to know, is to take a can of carb cleaner that is safe for oxygen sensors and spray it around likely spots that are leaking while truck is idling. If you hear a change that's where the leak is.
Old Dec 18, 2003 | 12:20 PM
rodbeed's Avatar
rodbeed
also ive notice a loud hum of the fuel pump in the tank.could this mean anything?
Old Dec 24, 2003 | 07:31 AM
rodbeed's Avatar
rodbeed
could the fuel pump be losing pressure?
