Dome Light problem HELP!!!!!!!!!!
Old Dec 17, 2003 | 06:20 AM
DIABLO's Avatar
DIABLO
ok guy, i have a huge problem with my DOME LIGHT staying on when my truck is not running, all the doors are shut (i slammed them) dome light switch and cluster dimer turned down, doors locked with remote.
i have no idea what is going on here. but it stays on for about an average of 30 minutes!!!!!
and also on another note, when i am driving, the door ajar light stays on and the dome light is on also
i have checked all the latches, and dome light "buttons on the door jams, and have yet to find the problem
if anyone has had this problem and has fixed it, please let me know how it was done
or if someone has a "quick fix" that'll be good also
then if no then ill have to the dom light
thank you
CHEVY
Old Dec 17, 2003 | 06:33 AM
powerstroker250's Avatar
powerstroker250
Spray inside the latches with WD-40.
Old Dec 17, 2003 | 08:46 AM
99f250's Avatar
99f250
remove the bulb=quick fix
Old Dec 17, 2003 | 09:11 AM
AKDieselMan's Avatar
AKDieselMan
Spray with WD-40 or any other spray lubricant. See my post yesterday 'Intermitent door adjar light" and remember to let allow the timer to go off or get in and put the key in the ignition and turn it on. They will go out then. Use the little tube to get the lube down below the latch. I did it in the dark and it worked.
