01 Vibration
Old Dec 16, 2003 | 08:17 AM
Bucky's Avatar
Bucky
01 Vibration
I have an 01 powerstroke. I get a vibration in the steering at 45 to 55 Mph. It does it with two different new sets of tires. Brand new front lock outs. Any ideas as to what it would be?
Old Dec 16, 2003 | 03:30 PM
Strjock81's Avatar
Strjock81
Most likely ball joints unless you meant you had those replaced when you had the "hubs" done. Some SDs are just bad at some speeds, but if the ball joints are good and the alignment has been done and wheels properly balanced, maybe a steering damper would be a good investment?
Old Dec 16, 2003 | 09:50 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I would guess a bad u-joint on the rear shaft, or the carrier bearing (if you have one).
Old Dec 17, 2003 | 01:30 AM
Strjock81's Avatar
Strjock81
Would the carrier bearing or the U-Joint cause a steering vibration? I thought it would feel more in the whole vehicle...
Old Dec 17, 2003 | 11:19 AM
cookie88's Avatar
cookie88
FTE Emeritus
Well, I'm thinking that it may just "feel" like a steering vibration. Usually when the vibration occurs at a certain speed it indicates a u-joint is wearing out.
It may not be that, that's why I prefaced my comment with "I would guess".
