hpop housing
Old Dec 16, 2003 | 09:49 PM
charlie calcote's Avatar
charlie calcote
hpop housing
Last week my 2002 f350 would not start and finally after going thru different posts, i read about the high pressure oil pump housing may not have oil in it, and if so the the engine wouldn't start. I checked and there was only a small amount of oil in it. I filled it with oil and it started. My question is, why does it lost oil, is there a gasket or something I should check?
Thanks,
Old Dec 19, 2003 | 06:05 PM
grisman's Avatar
grisman
there are two high pressure lines (4 o-rings total), one flage gasket, and there are 2 o-rings on the pressure regulator.
Old Dec 20, 2003 | 05:44 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Was your engine hot or cold when it would not start?
If it was hot, then the IPR o-rings are bad.
If it was cold, then i think the only way for oil to leak out of the res. is throught the checkball inside that lets oil back into the engine. I removed my c/v's from the supply lines to the heads to allow more flow and oil has never leaked down through there.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
