Light Removal?
Old Dec 16, 2003 | 08:47 PM
jpjshy13's Avatar
jpjshy13
Question Light Removal?
I have a 93 F-150, and i was recently involved in a little off roading accident. I accidently climbed a tree and now i am fixing my truck. The problem i am having is getting the whole light fixture out. I need to get them out so i can replace the fiberglass underneath the whole grille. So i was wondering if anybody knew how to take the whole fixture out or if anyone has any websites that would help.. that would be great, thanks!
Old Dec 16, 2003 | 11:24 PM
Mil1ion's Avatar
Mil1ion
Did you post this in the 87-96 forum ?
This is more a mechanical question than Electrical.
Old Dec 17, 2003 | 12:45 AM
aikigod's Avatar
aikigod
I assume you're talking about the headlamp assembly? There are two screws on top of the assembly (the obvious ones everyone sees), and two bolts (lower on the lights) holding the assembly on. It'll make life easier if you move the washer/coolant overflow tank and battery out of the way. The bolts are hidden from view; poke your finger in the holes at the lower turn-signal level of the headlight assembly and you should be able to locate them. Then take a ratchet and extension - my bolt was 10mm - and remove (the lights, signals, and trim come out as one unit).
