Radio Light?
Old Dec 16, 2003 | 06:23 PM
Truckboy's Avatar
Truckboy
Question Radio Light?
Okay so I have the original AM push button radio, which works great, but was it supposed to have a light in it?
Old Dec 16, 2003 | 06:27 PM
NM5K's Avatar
NM5K
Most usually do, but some might not. "aftermarket cheapy, etc".
With a factory radio, the lights usually have to be on for the radio light to come on. There is a "light" power lead. If it has one, but doesn't work, the bulb in the radio is out. It can be replaced. MK
Old Dec 16, 2003 | 06:31 PM
Truckboy's Avatar
Truckboy
Do I have to remove the radio to get at this light?
Old Dec 16, 2003 | 06:40 PM
NM5K's Avatar
NM5K
Yes. And it might be soldered in . So you might need a soldering gun or iron, and rosin core solder. If it has one, I kind of doubt it has a bulb holder, although it's possible. If it's wired in, just clip the wires as close to the old bulb as you can, and wire in a new bulb with leads in it's place. If you solder, don't use acid core solder. You never want to use that for radio or other electrical stuff. MK
Old Dec 16, 2003 | 06:45 PM
Truckboy's Avatar
Truckboy
Thanks, I am assuming that I can remove the radio fairly easily from below the dash?
P.S. I really appreciate all the info and the help. I am getting a Factory Shop Manual on CD Rom but until then I am kind of stuck. I can usually figure things out but I have found that sometimes there are tricks that make these things easier or harder if you don't know them.
Old Dec 16, 2003 | 09:35 PM
BB's Avatar
BB
Radio won't drop out below the dash, remove the glove box liner and pull it out that way.
Old Dec 17, 2003 | 08:16 AM
Truckboy's Avatar
Truckboy
Awesome! See I would have wasted a whole lot of time trying to get it out below. Well maybe I would have figured it out but hey Thanks for the info!
Old Dec 18, 2003 | 07:52 AM
jeremyd72's Avatar
jeremyd72
Truckboy,
I have the factory radio in my 72 and the light bulb just snapped in from the top. I just took my defroster hoses loose and worked my arm up in there and pulled it loose to change it. Thats easier than removing the whole thing. Also, my light stays on all the time, night or day as long as the radio is on.
Jeremy
Old Dec 18, 2003 | 06:52 PM
mk's Avatar
mk
I think they use an 1895 bulb.
mike
Old Dec 18, 2003 | 08:57 PM
1968F250LWB's Avatar
1968F250LWB
mike
1895 is actually the ashtray light.
1893 is the radio dial light.
Take a gander at this site. It list all the bulbs you could need. Just put in the make and year.
http://www.sylvania.com/auto/carapp/
Old Dec 19, 2003 | 10:15 AM
Truckboy's Avatar
Truckboy
Well I can see I am going to have to take a serious look under my dash to see what all I have in the way of bulbs. I didn't even know that I was supposed to have a ashtray light. Thanks.
Old Feb 4, 2007 | 07:28 PM
rb1234's Avatar
rb1234
I have the same problem on my 1997 ford f-150 the radio works fine but the button lights wont't come on only the time and station button
Old Feb 4, 2007 | 10:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Radio Bulb
1968/72: 1891
1961/67: 1895
Old Feb 5, 2007 | 01:26 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Not all of them did. It was only on te higher trim models usually. same with the cigar lighter.
Old Feb 5, 2007 | 03:20 PM
Mil1ion's Avatar
Mil1ion
It was part of what was called the convenience package.
