Nitrous
Old Dec 16, 2003 | 12:29 PM
Ryan50hrl's Avatar
Ryan50hrl
Nitrous
If i wanna run nitrous on my new motor....i know i need forged pistons...but can i run aluminum heads or should i stick to cast iron?
Old Dec 16, 2003 | 12:54 PM
jwtaylor's Avatar
jwtaylor
Either head will work. You can also use cast pistons or hypereutectic, all depends on how far you wanna take it and your confidence in your/ or anothers tuning ability.
Old Dec 16, 2003 | 01:44 PM
f100guy's Avatar
f100guy
there is a good cheap system in jegs. you can jet it for 50 75 or 100 shot of nos. 100 shot is the safest i would go on a street motor though. i plan on getting it sometime.
Old Dec 16, 2003 | 01:58 PM
Ryan50hrl's Avatar
Ryan50hrl
i'm probably thinking only a 50 shot...since i do want this motor to last a long while...
Old Dec 16, 2003 | 08:32 PM
fordeverpower's Avatar
fordeverpower
If you want it too last don't use nitrous. That motor will run lean!
Old Dec 16, 2003 | 08:37 PM
Blurry94's Avatar
Blurry94
You could get a "wet" kit to aid in keeping it from leaning out. It's safer than a dry kit.
Old Dec 17, 2003 | 08:43 AM
jwtaylor's Avatar
jwtaylor
I am with blurry94, there is a general idea that a 100 hp shot is fairly safe, but again it has everything to do with your confidence in your tuning or anothers tuning ability. Good luck
Old Dec 17, 2003 | 10:51 AM
Ryan50hrl's Avatar
Ryan50hrl
To someone who has nitrous...if i'm planning on keeping my stock fuel injection what do i need to do for tuning with a 50 hp shot?
Old Dec 17, 2003 | 11:02 AM
jwtaylor's Avatar
jwtaylor
If you go with a "wet" kit, that means there is a solenoid for the fuel as well as the nitrous oxide, both come on at the same time. So theoretically given you add the right nitrous and fuel jets to the kit, it should balance out and you have to do nothing to the existing motors tune. You will probably get bored with the 50 shot in a hurry so if you get one that has a range of options the "wet" kit might be ideal for you. If you go with a "dry" kit then you rely on a signal being sent to your fuel pump/injectors to add more fuel at wide open throttle, if you begin upgrading the nitrous shot then you may need to replace the fuel pump or add an inline "boost a pump" type deal or add another pump all together as the nitrous system will demand more fuel than the stock pump could reliably supply. check this site out it explains things better than I can.
http://www.raceworx.com/wet_or_dry.html
NitrousAl
Appearance & Dress-Up
Sep 5, 2006 04:35 PM
edub32
Bio-diesel, Propane & Alternative Diesel Engine Fuels
15
Apr 9, 2005 05:33 AM
rockthunder
Oct 7, 2003 10:57 PM
88f350
Dec 30, 2002 11:14 AM
NitrousAl
1978 - 1996 Big Bronco
Dec 19, 2001 03:28 PM
