Differential fluid change
Old Dec 16, 2003 | 09:47 AM
scooter_1968's Avatar
scooter_1968
Question Differential fluid change
when I bought my truck it had like 155k on her. she now has 166k. not sure but when is it time to change out the differential fluid? if it's not broke. dont fix it.. If I change it is that any thing else that needs to be change out after I crake the seal to drain her (i.e filter )? what weight of fluid do I need to put back in her.thanks.
scott
93 5.0 aod. 2wd Not sure on the gear ratio>
Old Dec 16, 2003 | 10:25 AM
EPNCSU2006's Avatar
EPNCSU2006
Just get a gasket to seal the cover when you put it back together. No filter in there, but be sure to wipe out the crevices a the bottom of the case, that will be where dirt and other particles tend to settle. I've got GL-5 spec gear lube in mine, I'm not sure the weight I ended up using though. I'm thinking it was 80/85w90. If you have limited slip (trac-loc) you will need to get 4 oz. of friction modifier, and put that in before the gear oil when you are refilling.
Old Dec 16, 2003 | 10:32 AM
scooter_1968
Thanks EPNCSU2006,
How do I tell if I have a litmited slip (trac-loc) on my truck. wouldnt there be a trac-loc on the instrament panel for it? Dont have one of those.. . Is there a better brand to use?
scott
Old Dec 16, 2003 | 10:37 AM
EPNCSU2006's Avatar
EPNCSU2006
Look at the sticker on the door jamb under "axle codes" and then check the owner's manual or post the code back here if you can't find it there. I used NAPA oil, which is Valvoline but costs much less.
Old Dec 16, 2003 | 11:01 AM
scooter_1968
THANKS MUCH...
SCOTT
Old Dec 16, 2003 | 12:39 PM
gatesj's Avatar
gatesj
The sticker will have a two digit code. If the first place is a number it doesn't have trac-lock, if it's a letter it does. See this:
https://www.ford-trucks.com/articles/axlechart.php
You probably have an 8.8", so you just unbolt the cover on the back. I don't think there's a gasket, just clean up the surface and run a bead of RTV silicone around it.
Change interval is at 100,000 miles.
Old Dec 16, 2003 | 01:30 PM
scooter_1968
gatesj thanks for the info I'll check mine when i get home.
scott
Old Dec 16, 2003 | 08:10 PM
EPNCSU2006's Avatar
EPNCSU2006
Yeah, RTV or a gasket, doesn't really matter, both will work. It's entirely up to you.
Tomcat7742
1997 - 2003 F150
37
Feb 26, 2017 09:13 AM
Bubba Jones
1978 - 1996 Big Bronco
Mar 29, 2012 03:01 PM
gmetime24
May 21, 2011 04:22 PM
homer4.2
3.8 & 4.2L V6
Jul 2, 2004 09:44 AM
basstardo
Jun 25, 2003 07:59 PM
