Intermittent wiper conversion.
Old Dec 16, 2003 | 06:19 AM
f100beatertruck's Avatar
f100beatertruck
On my 86 F150 XL, how hard would it be to convert my two speed wipers to 3 speed intermittent?
Old Dec 16, 2003 | 07:09 AM
Big Red's Avatar
Big Red
Not a problem at all. I did that last year on my '83 F100... best option I ever added. You need to find an intermittent switch unit from a junk yard or where I got mine... eBay. I think they are all the same from '80 thru '86. Make sure you get the switch and "black box" attached with the wiring harness. Then just remove the old one and the new one just plugs into the same harness... no need to change the motor. Remember to attach the green ground wire to a good under dash ground.
Old Dec 16, 2003 | 08:57 AM
Oscar Meier's Avatar
Oscar Meier
Ditto - The hardest part is getting the **** off the wiper control shaft.
You need a hook arrangement to depress the metal keeper up into the **** to pull it off the shaft.
Don't think you can just pull it off - It's like a chinese finger trap - the harder you pull the tighter it gets.
Chiltens manual has instructions on **** removal. BigRed is right any 80-86 control will just plug in and it works great - a huge difference over the old two-speed control.
Old Dec 16, 2003 | 09:04 AM
Big Red's Avatar
Big Red
Yes the **** would be an issue... my old one was broken and would fall off by itself. The one I installed had a **** with it so it just snapped in place when the new unit was installed.
Good Luck!
Old Dec 16, 2003 | 06:23 PM
f100beatertruck
Cool... Thanks guys.
Old Dec 16, 2003 | 07:51 PM
Bueller's Avatar
Bueller
Is it possible to just buy a new intermittent switch from the auto parts store and just plug it in?
Frank
Old Dec 16, 2003 | 07:53 PM
Big Red's Avatar
Big Red
Not sure but anything is possible. They come up on eay quite regularly... cheap too... I got mine fo $10.
Old Dec 16, 2003 | 07:57 PM
Big Red's Avatar
Big Red
As a matter of fact, there is one on ebay right now that will work for you.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2449020739
Old Dec 16, 2003 | 08:25 PM
Bueller's Avatar
Bueller
Well damn...I can't get my ebay account to come up for nothing. I hadn't used it forever, and tried to fire it up the other day, but it won't let me in :-( LOL so ebay is out of my reach atm (and that's prolly a good thing...........)
Frank
phoneman91
64
Feb 2, 2025 05:40 PM
Old Brown Truck
Feb 19, 2016 05:32 PM
Viperfoxbat
Jun 20, 2015 02:36 PM
omni
Jan 25, 2015 04:15 PM
Shadowrider123
Dec 31, 2014 05:05 AM
