Adding a 4x4
Old Dec 15, 2003 | 02:44 PM
coolride's Avatar
coolride
Adding a 4x4
Just wanted to know if anyone as ever done a 2wheel to 4wheel conversion. If so, is it worth the aggrevation. Oh yeah, I'm going from a 5speed 2wheel drive to a auto 4wheel drive. Thanks in advance.
Old Dec 15, 2003 | 04:06 PM
PSKSAM2's Avatar
PSKSAM2
Anything can be done to cars with enough time and money. I'm sure people out there have done it, but I would think it is tough. The differences between a 4wd and 2wd Ranger are more than just a transfer case and front driveshafts. For instance, the entire front suspension is different. In the end, you'll either have to swap a lot more parts (in which case it would be best to have a parts 4wd Ranger to cannibalize) or you'll have to custom fab a lot in which case you'll come out with an animal that can be tough to maintain. I would have to have a really good reason not to just go out and buy a 4wd Ranger before I'd attempt it.
-Jim
Old Dec 16, 2003 | 05:48 PM
98rangerstep's Avatar
98rangerstep
If you have your heart set on it, go with the solid axle and leaf spring conversion. There is a lot less holes to drill and parts to fabricate. I am currently researching it and it in my opinion looks a lot easier.
Old Dec 17, 2003 | 12:23 PM
coolride's Avatar
coolride
Thanks for the encouragement, but what do you mean by less holes to drill and parts to fabricate.
Old Dec 17, 2003 | 05:11 PM
98rangerstep
nothing too hard, just some leaf and pick-up point brackets and the holes to mount them, unless you are going to weld them on. If you are just going to weld them on then you will have a stouter truck but it will make it harder to repair if you are intending to beat the snot out of it
Old Dec 19, 2003 | 02:30 PM
coolride's Avatar
coolride
Do you know roughly how it should take. Assuming I have all of the parts ready to go. My donor truck is a 1986 Bronco 4x4
Old Dec 19, 2003 | 02:32 PM
coolride's Avatar
coolride
Sorry, how long it should take . OOPS
Old Dec 19, 2003 | 03:10 PM
AlfredB1979's Avatar
AlfredB1979
Semi-easy way = swap your truck body onto a wrecked that hopefully has the drivetrain you desires still intact.
If you have a piece or two missing from the factory 4x4 frame/suspension, it's still A LOT better than piecing it together and carving a 2wd frame uip!
Jeffandtat
Jul 15, 2012 04:02 PM
bluesclu978
Feb 13, 2011 07:52 AM
MER
Mar 8, 2008 09:28 PM
TEXANFOREVER
1978 - 1996 Big Bronco
Apr 29, 2007 01:00 AM
dino360
Oct 28, 2004 09:22 PM
