no codes help!!!!!!!!!
Old Dec 15, 2003 | 12:23 PM
ARNO60's Avatar
ARNO60
HELP,1992 F-150 5.0 4X4,HAD TRUCK PUT ON COMP.NO CODES .TRUCK RUNS FINE WHEN RPM'S SEEM TO BE 1500 OR ABOVE,WHEN JUST CRUISING ALONG AT A POINT WHERE RPM'S
ARE 1500 OR LOWER THE TRUCK SEEMS TO SPUTTER ,LIKE STARVING FOR FUEL,CHANGED THE FUEL FILTER.USED INJECTORCLEANER,NEW PLUGS,WIRES,ROTOR,CAP.NO VACUUM LEAKS.AT IDLE WHEN HEAT IS ON AND LIGHTS ARE ON,THE AMP
GAUGE DROPS QUITE A BIT UNTIL IDLE IS RAISED.COULD THIS HAVE ANY TO DO WITH MY PROBLEM. THANKS!!!!!!!!!!!
Old Dec 15, 2003 | 12:27 PM
stepman's Avatar
stepman
It may. Make sure your charging system is in order. If the batt voltage drops below 10.6, the computer will cut out. If that is okay, check your EGR.
Old Dec 15, 2003 | 12:31 PM
ARNO60's Avatar
ARNO60
THANKS STEPMAN I'LL GET THAT CHECKED.
SpartanSV
1997 - 2003 F150
May 11, 2017 06:00 AM
fsuper
1997 - 2003 F150
Feb 2, 2017 11:47 AM
Thunderbeam
Sep 7, 2016 11:04 PM
04redstroker
23
Sep 10, 2013 11:51 AM
buba 11
Jan 28, 2011 07:44 AM
