long crank time
Old Dec 15, 2003 | 10:23 AM
smagma's Avatar
smagma
long crank time
I'll try to be brief, if possible. Bought an 01' F350 7.3l. The engine didn't run, but couldn't pass up the price. Ran all the tests I could (I didn't have much experience w/diesels, but I do now) there were to many codes to list. Compression test showed 300psi and I had read that it should be 500 to 600psi, so here I go tearing the motor apart. I replaced the rings and had the heads done. Got all done, still wouldn't start. I used the Star Tester to monitor the oil pressure and noticed it wasn't building much. With my vast knowledge of diesels I took the high pressure oil pump apart and the ck ball came out. After fixing that it started, but it took a long time and ran bad. After driving it many miles and replacing 4 injectors it runs better, but takes about 5 seconds or so to start. All codes are gone, except a wastegate code. Does anyone have any suggestions?
