gears
Old Dec 14, 2003 | 12:49 PM
boogity24's Avatar
boogity24
gears
my metal tag on my door says.....axel:17
whats my gears?
Old Dec 14, 2003 | 01:05 PM
thatdude's Avatar
thatdude
Look at the tag on the dif.....the first 3 numbers on the bottom line is the ratio
Old Dec 14, 2003 | 01:16 PM
460 Crew's Avatar
460 Crew
Man who cares about gears check out boogitys friends ta tas ! Does she ride in your trucks? LOL
Old Dec 14, 2003 | 02:07 PM
boogity24's Avatar
boogity24
where the hell is the differential?????and what do i have to take off?
Old Dec 14, 2003 | 02:09 PM
460 Crew's Avatar
460 Crew
on the pumpkin on ur rearend on the back where the cover is held by bolts 2 of them hold a thin metal tag stamped with your gear ration on them. either clean it off or take it off and wire brush it.
Old Dec 14, 2003 | 02:10 PM
thatdude's Avatar
thatdude
beginner eh? The driveshaft hooks to the dif.. There SHOULD be a tag bolted to one of the bolts.
take it off, clean it up and rread it.
Old Dec 14, 2003 | 02:11 PM
boogity24's Avatar
boogity24
alright, let me go see!!
Old Dec 14, 2003 | 02:23 PM
boogity24's Avatar
boogity24
it says: wdm-u 2ce
3.70 8 7 338a
thatdude's Avatar
thatdude
there you go
Old Dec 14, 2003 | 02:24 PM
boogity24's Avatar
boogity24
so its 3:70?
thatdude's Avatar
thatdude
yup
Old Dec 14, 2003 | 02:28 PM
boogity24's Avatar
boogity24
thanx alot everybody!!!
Old Dec 14, 2003 | 02:51 PM
thatdude's Avatar
thatdude
no problem, next time you have a question you might try doing a "search" for the topic.
I'm not getting on you about this, I have seen probably 50 threads about the same thing.
Axle Identification
Differential ID
Gear Ratio Question
9" ID Tag Code
etc.
ect.
I am always glad to help anyone I can. Good luck
