1996 E350 7.3 powerstroke temp problem
Old Dec 14, 2003 | 12:17 PM
JoeARein's Avatar
JoeARein
I recently purchased a 1996 e350 cutaway with a 7.3 powerstroke and have found that the heater blows cold air and the temp. gauge barely moves even after running for two hours. Motor appears to run well but simply does not register temp on the guage. Any suggestions on what to look for would be welcome.
Old Dec 14, 2003 | 01:18 PM
alanscott's Avatar
alanscott
That sounds like a thermostat problem, it's probably stuck open. Do a search in this forum for directions on changing it.
Old Dec 14, 2003 | 08:27 PM
ltfox's Avatar
ltfox
I had the same problem with my 94 psd. A new thermostat fixed the problem. No problems since!
Old Dec 15, 2003 | 06:40 AM
powerstroker250's Avatar
powerstroker250
You may want to replace the thermostat housing also, they tend to leak when reused.
Old Dec 16, 2003 | 11:08 AM
Oklahoma's Avatar
Oklahoma
A good way around the thin walled housing problems (coupled with the spout that is way too easy to pull at angles with) is to buy a large donut gasket to put in. I used one about 3 times original size. The round flat wimpy gasket that specs call for (at least for a 95) will leak even with RTV sealant if you have pulled, wrenched, etc to get the housing off and done some damage. A lot of RTV will work but not a good idea in this spot. The donuts are only $2 or so dollars.
powerstroker250
Jun 16, 2014 01:52 PM
chrisoroe
May 29, 2011 11:41 PM
powerstroke 96
38
Oct 16, 2010 01:22 PM
jbballcoach
Jun 19, 2007 09:10 PM
Rainman391
Mar 31, 2007 02:20 PM
