Sponsored by: Auxito
97 F 150
Old Dec 13, 2003 | 10:27 PM
Problem Man's Avatar
Problem Man
97 F 150
My Ncreen Name says it all i am a man with a problem
I have a 1997 f 150 2wd 6cyl my son managed to get it stuck in a few feet of snow with only two wheels on pavement so his friends father decides that it can be towed out from the front and hooks a tow cable up to a box presumably aluminum and rips it off red fluid flies and well the truck is still there, so the question is what is the little box behind the grill that contains red fluid by little i mean about the size of a size 9 mens shoe maybe smaller hopefull some one can help me and i appreciate all that at least read the post and admit that they dont know what i am talking about because i have given few details which is all i know
Thank You again
Old Dec 13, 2003 | 10:32 PM
AwesomeBullet's Avatar
AwesomeBullet
Oops!
Sounds like the transmission cooler. Or the power steering cooler. Either way, not good to even fire it up until it is repaired...
Old Dec 13, 2003 | 10:41 PM
Ultramagdan's Avatar
Ultramagdan
Hello Problem Man and Welcome to FTE.
Ouch! I agree with AwesomeBullet. People are starting to find out that you just can't put a tow hook wherever you want. I will usually look a vehicle over before putting a hook on it. If I can't find a area that I can hook unto without ripping something off (or even bending something), I'll decline.
While the dad was well meaning, he is responsible for the damage done.
Old Dec 14, 2003 | 02:08 AM
ultraclassic's Avatar
ultraclassic
Yep sounds like the trans cooler to me
Isn't it strange that they put front tow hooks on 4wd and not the 2wd It seems to me that 2wd's need them more
Is the friend father gonna pay for the repairs or is he taking the "I am a good samaritan and not responsible for my own stupidity" approach"?
Old Dec 14, 2003 | 09:41 AM
Racerguy's Avatar
Racerguy
This sounds like one of those situations where there might not be a right way to do things. The person that did the damage should be responsible but he did probably save the cost of a tow truck and was just trying to be helpful.
Old Dec 14, 2003 | 02:51 PM
leroys4wd's Avatar
leroys4wd
whenever I pull someone out I make them hook it up and tell them I'm not responsible if anything comes off.
Old Dec 14, 2003 | 06:32 PM
geoaigel's Avatar
geoaigel
I think it may be the power steering cooler. I don't think the trans cooler is exposed as much as the p/s cooler.
George
Old Dec 17, 2003 | 10:14 PM
Problem Man
Thanks fellas sure was the dang power steering cooler and it only took a few dollars to replace
Truly thankfull you all could help
