no power
Old Dec 13, 2003 | 08:43 PM
downdeephuskyjerk's Avatar
downdeephuskyjerk
no power
replaced my alt a couple of weeks ago.....everything seemed ok. this morning it was 10 deg out here in michingan and i was trying to start the old truck.....it started cranking like it was going to start then nothing...........no lights radio nothing......12vdc on the battery. where should i go from here? 1993 f150 4.9l
Old Dec 13, 2003 | 09:21 PM
HomerWinzlow's Avatar
HomerWinzlow
A lot of the time its simply corrosion on the cable. It can be so light that you cant see it without removing he cable ends and cleaning them thoroughly. If it has had the terminals replaced in the past the wire strands that attach to the replacement terminals may be corroded enough to not make proper contact.
Old Dec 14, 2003 | 09:52 PM
Duderoy's Avatar
Duderoy
Yes check your cables first, but I had a battery that would short internally when it was under cranking load. Once it would short it wouls barely light the lights.
Old Dec 15, 2003 | 03:11 PM
downdeephuskyjerk
you guys were right on the money....corrosion on the positive battery cable. cleaned both cables and the beast fired right up thanks for the help
