trouble codes
Old Dec 13, 2003 | 04:47 PM
wrongsideup's Avatar
wrongsideup
Question trouble codes
I can't find where to plug in my code checker? I was told to look under the hood on the passenger side but, I don't see anything. Do I need to unplug anything or is there a pigtail I haven't run across yet?
Old Dec 14, 2003 | 07:35 AM
nbswelding's Avatar
nbswelding
What year I wonder??? If you have an '88 or newer you don't need a checker to get trouble codes. You just need a little 6" jumper wire to go from the STI (self test input) to the signal return pin on the wire harness behind the air box. If you don't have a check engine light. Get a Haynes manual #36058 and look in chapter four section 14. I think you will only need a special tool if you have a '96 or newer.
Old Dec 14, 2003 | 10:27 AM
wrongsideup
Lightbulb code checker
You know this is the second time I have gone to this forum and left all the important information off, kinda like going to a fire and leaving the fire truck at the station.
The code checker I bought is for a string of years in which my truck is one. If that don't help then I'll tell ya it's a 1990 F-250 with a 460cui engine, Automatic trans.
Old Dec 14, 2003 | 11:51 AM
i_alone's Avatar
i_alone
Look on the drivers side, by the hood hinge, I know my dad's 93 w/ 460 has it there
justinbrh88
May 4, 2014 10:30 AM
wildstang
Aug 28, 2013 09:52 PM
Techfree
2004 - 2008 F150
Dec 20, 2010 07:58 PM
billfishnut
18
Mar 14, 2009 09:09 AM
wresleu
1997 - 2003 F150
Nov 14, 2007 08:35 AM
