4 thousand miles away!
Old Dec 13, 2003 | 11:34 AM
Saigon's Avatar
Saigon
Question 4 thousand miles away!
Hello to all,
Being 4 thousand miles from home I need some help ! I have a simple front caliper brake problem and no solution!!!
I have to replace the pin assembly on both front calipers on my 1985 F-250 4x4. These are the pins that hold the calipers to the kingpin assembly, I have a bit of play in them and it clunks bad around corners.
I have to find a website to order these as where I am F-250's are about as common as watering holes for oysters!
If anyone has a good website address, don't hesitate !
Thanks,
Magic
Old Dec 13, 2003 | 10:22 PM
dieselzen's Avatar
dieselzen
Mike,
Thought I'd post something. Don't know if this is what you're looking for. I've never done business with them. I am giving the link of their shipping faq. You can follow the links to their home page:
http://www.autopartsworld.com/faqs.asp
Also, I've found several sites which will ship to an APO or a FPO. Does the FPO stand for "Foreign Post Office"? R.A.
Old Dec 14, 2003 | 05:15 AM
Dave Sponaugle's Avatar
Dave Sponaugle
I had the same problem. I put 4 small weld spot beads on each and then filed them flat in the V where the pins go. Tightened the pins right up, no rattles, everything is good to go. Mine only had to be about 1/16" high after filing it flat to fix the rattle. Did that 5 or 6 years ago, still no rattle.
Old Dec 14, 2003 | 05:37 AM
Saigon's Avatar
Saigon
Thanks for the responds, wiil check the site out and Dave, I was thinking about going the "welding spot " way too, I can always put new ones in later.
thanks,
Magic
