Tachometer
Old Dec 13, 2003 | 11:23 AM
86straight6's Avatar
86straight6
Tachometer
My 86 didn't include a tach...
I was wondering how hard it would be to install one...I assume that if I purchase an aftermarket one it will include a cable...how would I hook it up?
Also, what is the redline for this engine? What are the suggested shifts?
Thank you!
Old Dec 13, 2003 | 12:03 PM
Bogn's Avatar
Bogn
3500rpm for the fastest acceleration stock, I shift at about 2500 for daily driving. True redline is about 4500rpm, at about 5000 she starts to vibrate pretty good.
Old Dec 13, 2003 | 06:04 PM
cdherman's Avatar
cdherman
Most aftermarket tachs need only a wire to the distributor terminal on the coil. Really pretty simple. Of course, where to mount it is a different story.
Some older setups were cable driven, like a speedo. But those are very uncommon now.
Old Dec 13, 2003 | 06:33 PM
wildjon300ci's Avatar
wildjon300ci
If you find a truck at the local boneyard with one....it a plug and play swap.
Old Dec 14, 2003 | 12:05 AM
fordeverpower's Avatar
fordeverpower
most tach have 4 wires. One the negitive side of the coil, a ground, power, and light.
Old Dec 14, 2003 | 08:24 PM
knocturnal's Avatar
knocturnal
yours vibrates at 5 k... mine has a rev limiter at 5k.. so that means DONT GO OVER 5 K... lol
Old Dec 15, 2003 | 12:02 AM
Redneck-Cowboy's Avatar
Redneck-Cowboy
My tach has 3 wires. Ground then a green and yellew I plugged into the plug off the coil. I run mine up to 4000 rpms, but recently run her over a few times doing some fancy shift work playing in the snow with my friends.
Old Dec 15, 2003 | 01:49 AM
bigbadjs's Avatar
bigbadjs
Yeah, junk yard is your best bet. find a cluster with a factory tach and maybe you can pickup some other useful stuff while your at it. The whole cluster should just bolt in.
Old Dec 15, 2003 | 11:25 AM
custom_truker's Avatar
custom_truker
Anybody ever just use a stand alone adjustable shift light? I mean, if the whole idea is not to over rev the engine, or hit your shifts for maximum acceleration, then why not go with an adjustable shift light? I know that proform makes a light that you is adjustable, and doesn't require anything extra added to the stock ignition and cost only $25. Anyone ever used one before?
Old Dec 15, 2003 | 11:28 AM
Vampiro's Avatar
Vampiro
1 wire to the coil tach test 1 ground and 1 power wire. thats it
