Cab Mount replacement!!!??
Old Dec 13, 2003 | 11:07 AM
jmayer's Avatar
jmayer
Hey guys, can I get some advice on how to go about replacing my driver's side cab mount? Do I just use big rivets to install the new one?
Jay
Old Dec 13, 2003 | 12:03 PM
krazdndenver's Avatar
krazdndenver
It depends on whos you got, I have seen some that bolt on, when I did mine with parts from *** I welded them on. The best way to do these would be to remove the cab and work upside down.
Robert
72 F100 Ranger XLT W/ 86 5.0L W/AOD
www.geocities.com/krazdndenver
Old Dec 13, 2003 | 12:37 PM
jmayer's Avatar
jmayer
Removing the cab....
That sounds like a big job! I would assume this means having a tall hoist and a number of guys, and unbolting the cab and the fuel lines and steering...etc=a ton of work. Is this what you mean? Thanks!
Joshua
Old Dec 13, 2003 | 05:24 PM
lastchance's Avatar
lastchance
I've bolted them in myself already. I've never done any real restoration type work, just getting them to pass inspection type repairs!!! Get the bolt out if you can through the access cover in the floor. If it won't come out be prepared to chisel the nut/washer off from the bottom, or cut the nut off. Jack the cab up a little with a block of wood out near the rocker panel and cut away the rusted portion of the mount. Slide the new mount in, making sure the top (front) lip of the mount is under the seam that sticks out of the firewall. Then just bolt it through the firewall and floor where you can get good strong metal to draw it to the old cab. If you're planning to do a restoration you might want to take it to a shop and have it welded in, it will make a better looking job. If there is a body shop near you you might ask them for a price...it's a pretty common repair. But if this is just a daily driver type truck you can have it in yourself in a couple hours!
Old Dec 13, 2003 | 06:36 PM
jmayer's Avatar
jmayer
Mount and M350...
Thanks for the advice!
Cab Mount: In your advice, you don't meantion how you got the old mount off, or if you stuck the new one on over it...what did you do?
M350: Never heard of one! Do you have pics or a description?
Thanks,
Joshua
Old Dec 13, 2003 | 11:26 PM
rebocardo's Avatar
rebocardo
Using "Made IN USA" 1/4 inch, grade 8 bolts, should be fine for bolting it in. Do not use rivets, they are designed for clamping and not shear forces.
Old Dec 14, 2003 | 08:25 PM
jmayer's Avatar
jmayer
Talking Removal...
Hey Rebocardo, do I have to air chizel the old one off, or just stuff the new one on over the old...what do I do? Thanks for the earlier info!
Joshua
Old Dec 14, 2003 | 10:29 PM
lastchance's Avatar
lastchance
You'll want to at least remove the rotted parts of it. From there on use the new cab mount as a guide to see how much you have to get out to make it fit properly. I guess a lot of manufacturers make these mounts and I've had them already that would pretty much slip completely over an old mount. Then again I ran into some that required a little more cutting. You'll know better when you get in there and try to fit it!
And the M350 is the "Mercury" version of the F350...from back in the past when Ford sold trucks in Canada under the Mercury nameplate ( I think from 1947 to 1968)
Old Dec 15, 2003 | 10:40 AM
jmayer's Avatar
jmayer
Thanks, Bill. That info helps. There's not much room in there to move around...what did you use to cut away the rotted stuff?
J
