My Truck is not running well. It feels like a fuel filter problem, starving for gas? I change the fuel filter every 5K, but the problem rasies it ugly head every 1k miles.
It surges when going up hills at about 3krpm
Truck Specs
97 F350, 460 7.5L, 4.10 rear, 215K miles.
KN FIKP, Cat Back system.
Just changed Plugs, wires & FI cleaned.
Cleaned MAS sensor.
It seems like there might be another inline fuel filter that I might be missing?
Dual tanks?
If so,does it do it on both tanks?
What I am getting at,is that if it is a fuel starvation problem that acts like a filter it may very well be a marginal (worn out) fuel pump.
Unless you can isolate the problem to one tank or the other, I'd take a good look at both in tank fuel pumps. They wear out and cause the exact symptoms you're experiencing, I replaced both in my '89 and it solved the problem.
It fairly simple to do, run the tanks as close to empty as you can, get a buddy to help, and lower them down. It can be done fairly easily in an afternoon in your garage. A couple of bolts in the straps is all that's holding them there. Make sure you disconnect the filler hose first!
The fuel pumps just unscrew from the top of the tank. You can test them for operation, I forget what the rate they're supposed to pump is, but if they're shot, it's pretty obvious.
I replaced mine with units from a wrecker, I'm cheap. They worked great and I had no problems. I'm sure you can buy them from Ford, but I have no idea what they'll set you back.
[updated:LAST EDITED ON 08-Dec-02 AT 08:16 PM (EST)]I have dual tanks, it happens on both tanks. I always run them dry, alternating each tank, hoping to keep the crap from building up.
Originally posted by ramarionjr [updated:LAST EDITED ON 08-Dec-02 AT 08:16 PM (EST)]I have dual tanks, it happens on both tanks. I always run them dry, alternating each tank, hoping to keep the crap from building up.
Great work boys... The wife's chebby is doing something similar. We changed the filter a month ago and she said it is still acting up. (she was scared to tell me cuz I told her we were going to go trade it on a Powerstroke ). I might check on how much it cost's for a fuel pump. Thanks one last shot before we trade it for a blue oval.
