B4 Axle on E250 Van
1. The B4 axle / differential on my 1996 Econoline 250 has a varying pitch howl / whine. It is a high pitched whine at any speed over 20 or 30 mph. At 5-10 mph, it is a low pitch howl, reflecting the frequency of the gear contact.<br>
2. I Purchased the van (for the right? price) at a Gov. auction a month ago. Have driven the van for at least a thousand miles, with no apparent change in the sound.<br>
3. From another post at this site, its listed B4 axle is: Limited Slip, Dana 60, 4.10 ?<br>
4. If in park and each tire is alternately jacked off of the ground, there is barely ANY backlash! It is almost TIGHT. Is this normal for a "limited slip" differential? My concern is that the mesh on both sides is too tight?<br>
5. My wife's '96 Suburban K1500, 4x4 has about 3" of backlash on the periphery of the tires when off of the ground, which is what I am familiar with on most vehicles that I have owned in the past.<br>
6. Besides the questions in (3) & (4) above:<br>
a)Is there a way to determine if the whine is being caused by either too tight or worn gears instead of worn bearings in the "pumpkin?"<br>
b) If it is a gear mesh problem, can each side be adjusted independently? If so, how much backlash should be observed at the periphery of the tire?<br>
c) Can I get a used B4 pumpkin & change the gears and/or bearings myself? Doesn't look like these were designed for a simple "pumpkin switch" like was possible with some older cars.
<br>
Thanking ANYONE in advance for ANY feedback.</b>
