Free Van!!!!!!!
Old Dec 12, 2003 | 09:02 PM
fordaholic351's Avatar
fordaholic351
Free Van!!!!!!!
I thought since i got your attention now.
Could anybody tell me how to pull the motor on a van.
I`ve postted a couple of times but no one has replied.
Is there any tricks or tips you could help me with?
There has to be some heplful FORD VAN GUYS OUT THERE.
Thanks for any help you can give me.
Dustin.
I`m a fordaholic!
PLEASE HELP!
Old Dec 12, 2003 | 09:12 PM
pfogle's Avatar
pfogle
The only thing I can tell you is that the grill and radiator HAVE to come out (big DUH there!), there really isn't an easy way to do it.
Old Dec 13, 2003 | 03:08 AM
BlueAngel69's Avatar
BlueAngel69
well do u want to save the body? if so losen the body mounts up and then (keep in mind the front of the Van needs to be gone bye bye. )cleared out and then pull the mounts and and useing a motor lift pull the motor out PLEASE make sure all wires are unhooked the pipes are gone also it makes thing so much eazier to teanker with . if u and rip the motor down like alt. power steering and water pump AKA fan and fan clutch. offok well best of luck.
Old Dec 13, 2003 | 10:55 AM
lrd56's Avatar
lrd56
van motor removal
take out the front seats take off the pasenger front door take out the motor where the passenger door was .
Old Dec 13, 2003 | 02:55 PM
packlet's Avatar
packlet
removing pasenger seat and doormay be necessary for the older vans where the motor is in between the front seats, but for the 75-91 models, i know you can get it out from the front of the van. no need to remove anything from the interior but the doghouse. you do need to take out the front grill, cross bracing and radiator up front there, of course.
pretty sure a chilton's or haynes manual would give you more details on how to get the motor out. probably good $12-16 investment, if you don't have one already.
Old Dec 13, 2003 | 11:40 PM
Kaleo's Avatar
Kaleo
I can't remember exact details, but my dad pulled a 300 out of a 77 we had years ago.
The radiator, grill, and cross brace was taken off. Then the motor was stripped down to the block. Engine lift was hooked as close to block as possible.
Old Dec 14, 2003 | 09:58 AM
76Chateau's Avatar
76Chateau
Just replaced my last year it comes out the front,like some of the other posts, remove the radiator,grill and the cross member and remove everything on the front of the motor. They make a plate with a hook that attaches to the intake after you remove the carb so you can the engine lift as close as possible to pull it out.Goodluck !!!
Old Dec 14, 2003 | 05:30 PM
fordaholic351
Thanks for the guy, I appreciate the help.
Dustin
Old Dec 15, 2003 | 09:54 PM
Hanslip's Avatar
Hanslip
engine in
I mentioned to another poster about the Hayne's manuals for Econolines. They are quite helpful. You can get them from any supplier, ie:Napa etc. As for installing, how about first have a dry place to do the work, then rent or borrow an engine hoist. If you get the manual it's got all the steps plainly laid out.
Good luck, Stryder.
FORDAHOLIC
Aug 11, 2013 07:16 PM
FORDAHOLIC
May 4, 2009 10:59 AM
fordaholic-67F100
16
Mar 14, 2004 07:56 PM
Ford_a_holic
17
Jun 1, 2003 07:42 PM
