'89 f-150 fuel problem
Old Dec 12, 2003 | 07:10 PM
dirtyoletruck's Avatar
dirtyoletruck
after letting my truck idle for a few minutes in a parking lot i shifted into reverse, and the truck died. i've narrowed it down to a fuel problem, though i don't know what it could be. i've replaced the high pressure inline pump just recently and replaced the rear tank and low pressure in tank pump as well as fuel filter. i have also replaced the fuel pump relay. there is no pressure in the line and all of the connections are good. any ideas? thanks
Old Dec 12, 2003 | 10:56 PM
LxMan1's Avatar
LxMan1
It could either be a bad ECM or possibly a bad Ignition module. The pump runs as the ecm see's pulses from the pick-up in the distributor.
These would be a good place to start looking.
Jimmy
Old Dec 15, 2003 | 02:42 PM
ARNO60's Avatar
ARNO60
i have the problem i'm going to change the pick up,i'll let you know if it helps.
Old Dec 15, 2003 | 02:44 PM
ARNO60's Avatar
ARNO60
what is the ecm
