Tranny conversion
Old Dec 12, 2003 | 07:08 PM
19903024x4's Avatar
19903024x4
Tranny conversion
I have a 1990 f-150....302 AOD tranny.........do they make a kit or somthing to convert to a manual tranny?....or is this not even worth trying?
Old Dec 13, 2003 | 01:15 AM
f100guy's Avatar
f100guy
it can be done but you are going to need to find a truck in the junkyard with all the parts.preferably a truck with the same exact look.example, if you have a reg cab short wheel base get the parts off of one that looks just like it so the driveshaft will be the same size. get the pedal, tranny, bellhousing, flywheel, shifter, slave cylinder and lines or cables if it is a cable actuated. you may need the crossmember to. it would be best to go ahead and buy a new clutch. there is no telling how good or bad the one in the junkyard is.
