Remote key entry
Thanks
You need to "cycle" the ignition system 8 times within 10 seconds- in other words, rapidly turn the key between "on" and "off." You should end with the key in the on position. At this point the doors will lock and unlock, indicating that you have keyless remote entry and the system is ready to program the remotes. (If they don't lock and unlock, then you don't have KRE.) Just press any one of the buttons on a "3-button" remote (lock, unlock, panic) and the locks should respond. If you happen to have a spare remote around, go ahead and try it- you can't hurt the system. If it doesn't work, then it's time to see your friendly local Ford parts department. They'll get you the right remote.
