Intermittent ABS light?
Old Dec 12, 2003 | 11:42 AM
rapdes's Avatar
rapdes
Question Intermittent ABS light?
My 94 x has intermittent light up the ABS light. It will stay on after the ignition is turned on and won't turn off until I turn off the vehicle again. Sometimes I can start the truck 2 or 3 times in a row and the light will stay on, other times I can turn the truck off and when I turn it back on the light stays off. Anyone else had this problem and were you able to track down the cause? (when this happens I don't get any other error lights)
Old Dec 15, 2003 | 03:27 PM
Inger's Avatar
Inger
I just had a very similar proplem in my truck. Have you checked the brake fluid level? Mine looked okay at first glance, pleanty in the reservoir above the min level, but depending on the angle I parked at, it was a tiny bit low. Try topping it up. it might help.
Old Dec 16, 2003 | 09:54 AM
Jet Lizard's Avatar
Jet Lizard
It seems that one of the ABS sensors is acting up. Or its wiring harness, the symptoms are the same.
Try to check wiring harness connectors near ABS sensors. Also you may check the front sensors' resistance. Normally it should be between 1K and 1,4K ohm. Not sure about checking rear sensor (it is located in rear diff).
The same problem has been discussed here not so long ago:
https://www.ford-trucks.com/forums/s...hreadid=179834
With best regards,
Yuri
jhl3
Apr 4, 2015 04:03 PM
talltorontoguy
Jan 22, 2014 11:05 AM
like2ride
2004 - 2008 F150
Apr 20, 2012 11:08 AM
watzatruck
Mar 1, 2010 12:44 AM
ktm520mxc
Aug 13, 2004 11:52 PM
