Back-firing 300
Old Dec 12, 2003 | 10:01 AM
wolf1981's Avatar
wolf1981
my f-150
Can anyone help me out? I have an 81'f-150 with an inline six and its been backfiring every time i put a muffler on it.And also it just dies on me,it runs fine but it just quits after it dies it will start back up with no problem.I'm wondering if it might be electrical or not?
Old Dec 12, 2003 | 06:11 PM
35l911's Avatar
35l911
its probably your timing did you tune it up i.e. spark plugs, dist, roter,spark plug wires, coil thats the first thing i did on my truck when i got it
Old Dec 12, 2003 | 06:45 PM
desperado_18_2000's Avatar
desperado_18_2000
It sounds like when you add the muffler, its creating too much back presure for the engine to continue running normally. I'd check your catalytic converter, check your timing, and make sure you aren't running lean from a carb mis-adjustment.
Old Dec 12, 2003 | 06:49 PM
BlueTorpedo85's Avatar
BlueTorpedo85
Yeah I'd check the cat too. I blew up two mufflers in two days before my mechanic just gutted the cat. Fixed that problem
Old Dec 14, 2003 | 07:14 PM
wolf1981's Avatar
wolf1981
cat
I gutted the cat before it started back fireing.Friday i rebuilt the carb. and gave it a tune up.I guess I'll try another muffler.I've been using factory mufflers but I guess i'll try a glass pak..............THANKS FOR THE TIPS
Old Dec 15, 2003 | 12:44 AM
desperado_18_2000
How well does the truck run without the muffler on? if it runs decent without it, then there is a restriction somewhere that should not be there. If it runs fine without a muffler i'd look heavily at your exhaust, it could be that crappy flapper thing thats in the exhaust manifold, if it got stuck then that would indeed create too much back pressure.
Keep us updated.
Old Dec 15, 2003 | 10:29 PM
wolf1981's Avatar
wolf1981
flappy thingy
Well my truck does not have that little flappy thing on it.I guess I'll have too replace the whole exhaust system.But on another note the darn thing is still dieing on me and i can't figure out why.I'm thinking electrical somewhere
Old Dec 18, 2003 | 06:50 PM
Black Ford XLT's Avatar
Black Ford XLT
BACK FIRE
Wolf try (if u have one) take the belt off for the air pump-my 1985 was doing this last summer and we took this off and no more back firing. Hope this helps TR (what a back fire she was making , louder than a shot gun)
Old Dec 18, 2003 | 11:44 PM
jdon88's Avatar
jdon88
I have the same backfiring problem with my 1980 351M that is
Old Dec 18, 2003 | 11:45 PM
jdon88's Avatar
jdon88
Old Dec 18, 2003 | 11:49 PM
jdon88's Avatar
jdon88
I have the same backfiring problem with my 1980 351M that is caused by the air pump. There is some anti-backfire valve there (I forget the real name of it) but after replacing it I still have the problem. I just take the belt off as mentioned in the post above. I put the belt on for it to pass emission inspection then take it back off.
Old Mar 3, 2004 | 10:29 AM
rjrjs's Avatar
rjrjs
I had the same backing firing (leaning) and kept blowing muffers. There is an air pump bypass that works when decelerating, high vacuum to stop pumping air into the exhaust. Mine stuck open. Rather than replace the bypass valve I just took off the belt from the air pum. This completely stopped the exhaust pop.
