Ok, heres my problem. This truck I got has been sitting for a few years. None of the bulbs really worked, so i replaced them all, and the flasher. I still am not getting any passenger side light (execpt for headlights), and my flashers on the drivers side dont work either. Now, going through my manual, im trying to reach a starting point, and from what I can tell, all of the Illumination lamps get their power from the throttle actuator? Thats where i can trace everything back to. Is this right?
On most vehicles, the headlamps and the marker lamps originate from the headlamp switch. Even though they go to a common switch, they have different power sources or feeds to each. The headlamp switch also includes a seperate feed for the instrument lights.
The turnsignal lighting has a power feed to the flasher, and then goes to the turnsignal switch where it's routed to the brake lights in the back, and the turnsignal/marker lights up front.
