98 Expy Exhaust Question
Old Dec 11, 2003 | 05:28 PM
OregonTom's Avatar
OregonTom
What will happen if I remove the cat. coverter from the system and just ran duals, would the brain freak out? I am in a non smog tested area so no regs would apply. Thanks.
Old Dec 11, 2003 | 05:54 PM
southprk's Avatar
southprk
What would be the advantage of removing the cats?? Just wondering why you'd do it - there's basically no HP to be gained and it would freak out the computer a bit. Even though you're not in a smog-tested area, it's not a good idea to pollute when you don't need to.
Old Dec 11, 2003 | 05:59 PM
OregonTom's Avatar
OregonTom
Well I am trying to dodge replacing the one I got which i feel is plugging up...that was the reasoning, but I will replace it if there are no performance advantages in removing it.
Old Dec 11, 2003 | 06:01 PM
tyger25's Avatar
tyger25
Your check engine light would come on and stay on. The Cats in the Expy are the least restrictive Cats available, and it's true you would see very liitle to no gain in exhaust increase.
Old Dec 11, 2003 | 10:48 PM
tsdrallyer's Avatar
tsdrallyer
No adbantage at all, and it's a federal coast to coast law that you must have cats on the exhaust. Polluting the air happens whether testing is done or not.
Old Dec 12, 2003 | 10:55 AM
Frizzle's Avatar
Frizzle
you would get 10-15 hp without the cat
maybe even more
Old Dec 12, 2003 | 11:20 AM
southprk's Avatar
southprk
I'd be very suprised if you saw a 5hp gain from cutting both cats... Not to mention the fact it would play with your air/fuel ratio a little, be illegal, have more of a chance of backflow (backfire) etc..
Also, you could probably add 15-20 HP to my truck and I wouldn't know the difference simply because it's so heavy.
Old Dec 12, 2003 | 04:27 PM
pdqford's Avatar
pdqford
Re: 98 Expy Exhaust Question
The PCM is gonna notice that the post-cat O2 sensor is reading the same as the pre-cat O2 sensor, indicating that the cat is not consuming any oxygen, and it will light the MIL. The PCM may go into limp-home-mode and then you'll notice a drop off in performance..
Old Dec 12, 2003 | 04:28 PM
OregonTom's Avatar
OregonTom
Ok i am CONVINCED that i should replace it if faulty and not just cut it off. I was just curious to see if performance would be increased without a serious blow to the environment but I was wrong. Thanks for all the input.
Old Dec 12, 2003 | 04:33 PM
buzzard's Avatar
buzzard
Hey Southpark, removing the cats won't affect the air/fuel ratio. All the "downstream" O2 sensors do is monitor the effectiveness of the cats, but won't change the engine settings....this is accomplished by the upstream sensors.
I don't know how free flowing the cats are in today's vehicles, but I've gotta believe that they add some sort of restriction to the flow. I remember in the early '70 when they first started putting cats on passenger cars, those things would nearly choke to death any V8 made.
Old Dec 12, 2003 | 04:54 PM
tyger25's Avatar
tyger25
That explains it!!!!
Old Dec 12, 2003 | 09:15 PM
buzzard's Avatar
buzzard
Ouch!
If I could stand up, I'd whip you with my cane, sonny.
Old Dec 13, 2003 | 09:54 AM
boxcar_tommie22's Avatar
boxcar_tommie22
i have a 98 expy. and i just had the mufflers removed the cats are enough to dampen the sound...this expy sounds so sweet you would not believe it...i also have all three in pipe cat back..alot better then having duels which are very hard to squeeze past the gas tank....
Old Dec 13, 2003 | 09:58 AM
boxcar_tommie22
also, i learned that ford's use high flow cats...no restriction..
