electric fans
Old Dec 11, 2003 | 01:22 PM
bill6302's Avatar
bill6302
electric fans
i was wondering how much of an amp draw electric fans would draw
Old Dec 11, 2003 | 02:11 PM
lloyd33's Avatar
lloyd33
Depends how big of a fan it is, whether its one fan or dual fans, etc. A little 8" pusher fan might only draw 6 amps. A dual 12" fan setup could pull 20+ amps. What did you have in mind? If you can look at the box of the fan/fans you are interested in, it almost always tells you the current draw right on the box. You'll probably want/need to hook up a 15-30 amp relay for each fan you add, unless you plan on running them through a really heavy-duty switch.
Lloyd
