Which Starter??
Old Dec 11, 2003 | 11:55 AM
BillF250P's Avatar
BillF250P
Which Starter??
I am in the middle of building a '79 F250 4x4 400 with an AOD. It is an Art Carr trans, converter, and adapter plate. The flexplate is 164 tooth.Can I use a 351M/400 starter, or do I need to go to a 351W starter? I realize that it bolts up to the trans bellhousing and not the block, but I'm confused as to which one to use. I'm thinking of a Powermaster gear reduction unit. I know Ford uses a 157T flexplate/flywheel but I don't know if it's used on the 400. Also, I am thinking of twin-sticking the 205. Has anyone done this? I have to back a 5000lb trailer up my driveway. thru the garage, and into the backyard. It's so much easier to do this in 2WD lo range. with the 435 trans anyhow. I would be grateful for any help you could give me.....Bill
Old Dec 19, 2003 | 08:34 PM
BillF250P's Avatar
BillF250P
Does anyone know the ring gear tooth count for a stock C6 flexplate for a 400?
Old Dec 19, 2003 | 11:50 PM
Torque1st's Avatar
Torque1st
Posting Legend
Art Carr should be able to tell you what parts you need since it is their tranny and adaptor plate.
As far as the twin stick application check with the Trans diff and axle forum.
