Sponsored by: Real Truck
transfer case fluid change
Old Dec 11, 2002 | 07:36 PM
rvm264's Avatar
rvm264
I have a 02 250 psd sc auto 4x4 with esof, with about 13,000 miles. I was thinking of changing my transfer case fluid, does anyone have any recommendations on brands? my transfer case has been pretty noisy when in 4-hi since I have owned it, and I am hoping that the new fluid will help. I have driven around alot with the front axle engaged and it is nice and quite, but when I shift into 4-hi I get this growling type sound, for lack of a better word.I try to use the system as often as I can. thanks for the help.
Old Dec 11, 2002 | 07:59 PM
NoMo's Avatar
NoMo
First, loosen the upper fill plug- just to make sure it'll come loose. It'd suck to find that it's stuck AFTER you've already drained the TC.
Now that you are sure you can refill the TC, drain the factory fluid and replace with Mobil 1 synthetic transmission fluid. It takes ~2 quarts.
Old Dec 11, 2002 | 10:30 PM
rvm264's Avatar
rvm264
thanks for the help,NoMo
Old Dec 11, 2002 | 10:34 PM
haroutd's Avatar
haroutd
From: I'm lost somewhere in NJ -- can someone please find me?!?!?!?
NoMo -- I don't want it to seem that I'm questioning your knowledge (from what I've seen so far, you know your "poop") but is Mobil 1 synthetic Tranny fluid the best way to go in the TC? Is there any fluid that might be better? Also, will there be any performance gain by doing this? I plan on changing all the fluids on my truck over to synthetic come spring, but I have a compelling need to get my hands dirty NOW and wouldn't mind by doing this small task ASAP. I'm just curious if you think it will have any benefit for me.
Also, is this a simple drain & refill or do you suggest flushing it? How about draining, refilling with synthetic, running for a few miles, and draining & refilling again? Or am I just going overboard?
Old Dec 11, 2002 | 10:55 PM
NoMo's Avatar
NoMo
Thanks for the comment but it's more likely I'm FULL of 'poop' rather than knowing 'poop'. :P
What's "best" is purely subjective insomuch as what brand. I think most everyone agrees that synthetic lubricants outperform regular dino lubes. I like Mobil 1 because it's easy to find and doesn't have any of the "mystique" that accompanies some brands.
It's very doubtful that you'll see any performance benefit from just the transfer case. However, I'm confident that you'll see some (small) improvement once you convert everything to synthetics.
The transfer case only holds 1.8 (or so) quarts and you'll be able to get all but a very small amount of it out. So I don't see a need in flushing or doing any kind of "rinse and repeat" changes. Just drain and refill once.
Old Dec 11, 2002 | 11:57 PM
ColtM4's Avatar
ColtM4
Personally, I find the TC drains pretty completely and don't see a need to flush. I use Mobil 1 in both my TC and 6 sp tranny. I found my 6sp shifted better. just my .02
Old Dec 12, 2002 | 12:23 AM
prdprdprd's Avatar
prdprdprd
Another brand that I use as does several on the rescue team is Amsoil. They make a rated fluid for the transfer case in question.
Old Dec 12, 2002 | 12:54 PM
BigIron's Avatar
BigIron
Most people have a brand that they are particular about. I think the most important thing is consistency. Pick a brand a stick with it. Mixing brands all the time tends to create the problems.
I think most agree that Synth's are better all the way around and the price difference is worth it in the long run if it extends the life of the system.
Amsoil, Mobile, Castrol, Lucas (my pref); All good brands. Again, pick one and stick with it and you should have no troubles at all.
Good luck and let us know what you go with.
-Tony
Old Dec 12, 2002 | 01:23 PM
GAV10's Avatar
GAV10
I change mine every other oil change, and use Mobil 1 synthetic. The first time I changed mine it was black. Flushed it good, and changed it 500 miles later. No problems since.
GAV10 Mark
Old Dec 12, 2002 | 01:27 PM
haroutd's Avatar
haroutd
Even though NoMo went to the "dark side" recently, I'll go with his adivce and get Mobil 1. It's easy to get your hands on, and seems popular enough that it has to be pretty good. Thanks everyone for your help!
Old Dec 12, 2002 | 07:56 PM
Quikirk's Avatar
Quikirk
Which brings a question to mind. My 6 spd seems difficult at times to shift into 2nd, especially when cold. But even when it warms up 2nd seems to be the clunkiest to get into. The best way I can describe it is it's really notchy feeling. Is this normal? Is anyone else's this way?
Old Dec 12, 2002 | 08:12 PM
mkspear's Avatar
mkspear
kyle j
May 18, 2013 01:41 PM
jdhudall
1997 - 2003 F150
Mar 28, 2013 06:59 PM
mullins13
Dec 28, 2011 04:59 AM
bigred66
Aug 21, 2010 03:38 AM
