Transfer Case Fluid?
Old May 17, 2013 | 08:04 PM
kyle j's Avatar
kyle j
hey guys what kind of Fluid do i use when i change my T-Case fluid. is it just gear oil?
Type of fluid?
weight?
Thanks For the help
Old May 17, 2013 | 08:06 PM
tshrager's Avatar
tshrager
Type of fluid?
weight?
Thanks For the help
ATF. I believe merc V. Someone will correct me if I'm wrong. I can never remember if its 3 or 5.
Old May 17, 2013 | 08:12 PM
kyle j's Avatar
kyle j
thanks man, do you know how many quarts it will take?
Old May 17, 2013 | 08:24 PM
tshrager's Avatar
tshrager
3.5 in my 4407 or there abouts.
Old May 17, 2013 | 08:26 PM
Awitte58's Avatar
Awitte58
I googled this. Found a thread in PSN which had a link...
Here you go:
AMSOIL MyAMSOILGarage™ Recommendations - 1997 FORD TRUCKS F350 PICKUP 7.3L 8-cyl Engine Code [F] Turbo Diesel
And on that page when i searched 1997 f350 psd...etc.etc
Part way down the page there is capacities:
Capacities
Engine, with filter..........13.9 quarts [1]
Cooling System, Initial Fill..........22.7 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, E4OD Initial Fill..........6.4 quarts
Automatic Transmission, Total Fill
4 speed E4OD..........Not Specified
Manual Transmission, S5-47 (5-SPD)..........6.8 pints
Differential, Front..........5.9 pints
Differential, Dana 70-2U Rear..........6.6 pints [2]
Differential, Dana 80 Rear..........8.5 pints [2]
Differential, Ford 10.25 RingGear Rear..........7.4 pints [2]
Transfer Case, BW1356E W/ PTO..........12.3 pints
Transfer Case, BW1356E/BW1356..........4 pints
I bolded the stuff i think u want
Old May 18, 2013 | 01:41 PM
madpogue's Avatar
madpogue
^^^^ You'll notice two fill plugs. The lower plug is for the 4 pints for "normal" use, and the higher plug is for the 12 pints for when you use the PTO.
mullins13
Dec 28, 2011 04:59 AM
th67ss
Oct 23, 2010 08:51 PM
markjw
Mar 12, 2007 12:10 PM
racenitro
Sep 16, 2004 08:54 PM
