Tailgate insert
Old Jun 13, 2026 | 10:37 AM
1971F250 highboy's Avatar
1971F250 highboy
Trailering
Tailgate insert
Looking to get the back mounting plate off the insert that i have wondering how the best way to do it or if anyone has done it before any tips would be helpful
Old Jun 14, 2026 | 09:36 AM
manicmechanic007's Avatar
manicmechanic007
You need to remove the panel on the inside of the tailgate, then you have access to the nuts that hold that fancy Ford tailgate molding on
It looks like you have the fancy Ranger panel people like
Old Jun 15, 2026 | 08:00 PM
Green72F250's Avatar
Green72F250
I have never done this as I have a Sports Custom, but here are several quotes from folks that say they have done it. Good luck, let us know what worked for you.
"I was able to remove the aluminum panel. I was really careful to slightly bend the bottom crimp and loosen the metal back panel. Once free, the back easily popped out."
"The best way is to try and remove the rear panel is to shift the back panel to one end and then try to get it out of the front panel without uncrimping it too much on one end."
"If it gets uncrimped, you probably need to use a large metal brake to recrimp the part that was uncrimped to not damage the aluminum part."
"You are going to have to uncrimp at least one end (short side) and slide out the steel backing."
Old Yesterday | 05:37 PM
blue68f100's Avatar
blue68f100
I took mine off long long time ago (20+yrs) in prep for doing some body work and vaguely remember having to drill out some pop rivets.
KWRB
Nov 26, 2024 05:39 AM
06pghescape
2009 - 2014 F150
Jun 9, 2021 05:28 AM
MIKE1646
2009 - 2014 F150
May 24, 2017 01:44 PM
tlb
21
Feb 2, 2010 05:31 PM
keith56_cruz_cab
18
Jun 13, 2006 02:59 PM
