Differential fluid and additive
Old Today | 10:26 AM
Kybill1252's Avatar
Kybill1252
1st Gear
I have a 2004 F-150 XLT 4X4 4.6 engine. I'm changing out the rear wheel bearing and seals. got one bad on left side, so I'm going to change out both sides while into the differential. My question, thinking it's going to take 75/140 full synthic fluid, not knowing whether I have the limited shift rear end or not. Should I still should use the additive for the limited shift? What brand of 75/140 is the best brand to use?
Old Today | 01:23 PM
tjc transport's Avatar
tjc transport
i ain't rite
adding limited slip friction modifier to an open differential (if that is what you have) will not hurt anything
Old Today | 07:23 PM
meborder's Avatar
meborder
I get the valvoline bags at Walmart. Game changer
they have 75w140 and 75w90. Valvoline has the LSD additive already if you need it.
check your manual. The 8.8 with the 4.6 may only require 75w90.
Jamon Norton
15
Oct 23, 2023 05:49 AM
wizzy214
Feb 15, 2018 06:45 PM
newfie4ever
1997 - 2003 F150
23
Jun 20, 2016 08:04 PM
bgirard78
1983 - 2012 Ranger & B-Series
Nov 12, 2007 10:59 PM
blrman1962
Jun 18, 2007 12:28 PM
