Basic In-Cab Wiring Questions
Old Jun 10, 2026 | 11:27 AM
John in OkieLand's Avatar
John in OkieLand
Originally Posted by kenn_chan
just my thoughts, but if you were to take the trigger wire for the alternator and put a relay on it fed by the glow plug controller the alternator would put out zero amps while the glow plugs are on and as soon as they shut off via the PCM the alternator would start producing. no worries about the GP's or forgetting a switch or any fancy timers.
just my thoughts. i have the california emissions version with the weird shunt on the GPR so if i shut the glow plugs off it sets an emissions code hence my going with shutting off the alternator instead.
I have the California GPCM, not a relay,
so therefore, I do NOT want to puncture any wires to get that signal.
I will stick with my keyswitch ON signal to the programmable relay, set to 2:15 minutes
Old Yesterday | 07:37 PM
RacinJasonWV's Avatar
RacinJasonWV
Originally Posted by Y2KW57
All vehicles nowadays have bazookas (a term I learned at a GM/Toyota joint venture auto plant).
Never heard it called that. Guess I never heard it called anything before.
So they lured you to NUMMI with talk of bazookas eh?
F250_
Aug 18, 2024 01:06 PM
work.truck
Electrical Systems/Wiring
25
Dec 26, 2015 10:21 AM
EngNate
Dec 7, 2013 10:09 AM
BlueOvalBud
21
Mar 1, 2010 05:54 PM
429PI IN 75 f-100
May 20, 2009 12:22 AM
