Where should the pointer mark point to? I see three marks on the base, mine is pointing to the far mark. Any pics of a correct position.
01 f150 4.2 222,000
There should only be 3 marks total, 2 on the base and 1 on the arm that moves
The one that moves should be between the 2 on the base with the right belt on there
If yours is at one end, the belt should still work because that would still be between the lines
Was it hard to put on or does it seem loose?
Might be okay
Might be okay
