T18 to 5speed Question
Old Dec 11, 2003 | 01:18 AM
toml98's Avatar
toml98
Question T18 to 5speed Question
I have a 300 L6 with a T-18 transmission, and I'm looking to swap to a 5 speed. I know that there is a mazda 5 speed that bolts up to the L6. what I don't know is, well several things. First off, is there any difference in bell housing. Also, is there a difference in driveline lenght needed for these two trannys. Also, is the 5 speed compatable with the NP235 transfer case. Thanks for any input.
Old Dec 11, 2003 | 02:40 PM
Txquadhunter24's Avatar
Txquadhunter24
Yes, that Mazda Tranny can be mounted to your I6. The I6 302 and 351W uses the same bolt pattern. But I wouldn't replace the T18 for the Mazda they don't hold up well. If you want to do a 5spd swap look for the ZF 5spd found in F250 and F350 trucks with I6 to 351W. The Tcase will bolt up to it. As for the rest I have no clue.
Old Dec 11, 2003 | 02:53 PM
toml98's Avatar
toml98
thanks for the heads up on durability. do you happen to know the width difference between the t-18 and ZF 5sp. I'm curious because my exhaust has little clearance next to the current tranny.
Old Dec 11, 2003 | 03:01 PM
Txquadhunter24
I have no clue on that. You might try the Tranny forum lower down or the 87+ forums. I know there is a few old Post about people doing the ZF swap in the tranny forum so they maybe able to help ya there
80ford100
27
Jan 14, 2015 04:55 PM
Davidson IronWorks
Jun 22, 2010 10:51 AM
f100jim
Oct 25, 2007 03:57 PM
kameleon
Jan 31, 2002 09:12 AM
szczyrk
Jan 10, 2001 05:52 PM
