Was curious of the effect of insulating the block, head and pan to retain heat and having a large radiator and oil cooler (both with thermostats). Would this make the engine more efficient? (1994 stock 4.9L EFI 5sp-manual)
Still
You are onto something...
* The hotter the run, the faster they go
My Boss 302 "had" a 214 degree thermostat in it
Google "why Ford used a 214 degree thermostat in a 1969 Boss 302"
You go ahead and run hot if you want, just be careful
Fastest car I've ever been in was a 69 super bee with a well built 440 with a tunnel ram
He talked about blowing the radiator cap off his regularly
Mine was running so hot I couldn't drive it back when I first built it
NOPE, do some research on dragsters and race cars. Melting an engine is not a good thing. You are saying let's make it really hot then cool it wit a big radiator, they contradict each other. There have been air cooled engines, even V8's.
