Engine oil cooler, or not?
Old Apr 15, 2008 | 02:05 PM
camccardell's Avatar
camccardell
Question Engine oil cooler, or not?
Alrighty, I'm changing my water pump, and for probably the 4th time in 2 years, it looks like I need to replace the lower hose that goes into the oil cooler. I think that this is a little rediculous, especially since that piece of the hose is 30 something bucks. I am debating removing it and just using a 5.0 lower hose. If I did this I could also remove the cooler from the block and use the cheaper and better 5.0 filters. Any idea on this? I am concerned of oil overheating, that is is why I ask.
Also, I was dumb and put a chrome oil pan on the engine 2 years ago when I had to change the pan because it was leaking and rusted out. I now realize that this was a bad move on my part, since chrome holds in heat, not to mention the pan is allready rusting.
I was thinking of an oil radiator that I could mount in front of the radiator, but am unsure of how I would hook that up.
Any help, as always, would be appreciated.
Thanks
-Chris
Old Apr 15, 2008 | 03:46 PM
Virto's Avatar
Virto
You shouldn't really need an engine oil cooler unless you do a crazy amount of towing/hauling or plenty of high RPM operation.
If you're talking about the cooler on the bottom of the radiator, that's actually a transmission cooler, not engine oil. On trucks also equipped with an aux tranny cooler, the trans fluid passes thru the radiator cooler and then to the aux unit and back.
Replace that chrome oil pan, and if you're worried, try and get a finned replacement. That will lower the oil temp somewhat. I'd be a little surprised if you really needed an oil cooler, and if you have one and don't need it, it can keep the oil from reaching the proper operating temperature.
