Not another door ajar thread…
Old May 24, 2026 | 05:12 PM
Thirstymate's Avatar
Thirstymate
4wd Low
Found some bad jamb switches, replaced them… the last culprit is the driver door…
my understanding of the system is this;
the jamb switches operate in a normally closed electrical logic. Testing the jamb switches confirms this. Depressing the plunger opens the circuit.
removing the switch from the latch assembly, the plunger is out and the truck thinks the door is closed. Closed circuit.
depressing the plunger opens the circuit and the door ajar light comes on. Black ground wire has good continuity to ground, and the signal line is not shorted to ground. There is no switch produced, that I can find that operates in the required logic, IF , when the door is closed the latch assembly depresses the plunger… should the latch assembly depress the plunger with the door open and release when shut? The latch assembly logic is the only detail I don’t really have access to.
anyone else have a GEM module that looks for continuity at the driver door only? All other doors are now functional with the standard jamb switches.
Old May 25, 2026 | 05:29 PM
Thirstymate
4wd Low
The part number to reference to replace the door latch with the correct variation is 6C3Z-2521813-A. The door ajar switch logic is reversed in early years, 2001, some 2002 models year trucks.
If you have a 2003 and up, the truck is looking for the driver door to complete the circuit when closed. This latch part number provides the mechanism for the switch to accomplish that.
Early door latches do not, they complete the circuit when the door is open.
Old Jun 6, 2026 | 02:45 PM
'89F2urd's Avatar
'89F2urd
What are door ajar switches?
Old Jun 6, 2026 | 04:23 PM
01__Excursion's Avatar
01__Excursion
The white and red sensors.
billygoat
May 26, 2026 11:31 AM
Richie Whitworth
Dec 30, 2022 08:20 PM
DieselNation
Feb 16, 2016 02:57 PM
Gwilkrrs
Jun 14, 2014 02:22 PM
dorgan
Electrical Systems/Wiring
Apr 23, 2002 04:23 AM
