help me identify this device
Old May 24, 2026 | 11:38 AM
bullnose1984's Avatar
bullnose1984
4wd Low
Hello, does someone knows what is it? It's under my dash, it has a lever in the front and a tube behind
Thanks for your help
Old May 24, 2026 | 12:12 PM
BC2019F250's Avatar
BC2019F250
Looks like an old trailer brake controller to me.
Old May 24, 2026 | 01:02 PM
bullnose1984
4wd Low
Thanks, it is indeed a brake controller, found the exact same one on a youtube video
Old May 25, 2026 | 05:34 AM
FuzzFace2's Avatar
FuzzFace2
Yep and that tube tees into 1 of the metal brake lines.
When you step on the brakes the pressure is transferred to the controller that changes it to electrical and then send that to the electric trailer brakes.
If you follow the electrical side out of the controller a wire should go to an adjustable slide resister then to the trailer.
This adjustable resister is for when the trailer is empty / loaded as the braking power need to be changed or the wheels can lock up when empty.
This type of controller went away when ABS came out as they did not play nice together.
The new types, there are 2 different ones, all the adjusting is done at the controller and work really good as I have one in each of the 2 tow rigs I have.
Dont go for the cheaper Timed Apply as you cant really got then to work right, or I could not on the 1 I had for a short time.
The other type uses a pendulum and as you slow down it moves to apply power to the trailer, hard you stop the more it moves the more power out. and as said you can adjust the output right at the controller.
Dave ----
Igor M.
Nov 27, 2025 06:47 PM
SVandal
Sep 4, 2023 10:02 PM
Pistoltwo2
2015 - 2020 F150
May 8, 2021 11:09 AM
12amracer
Jan 22, 2013 04:07 PM
Angrywasp
Jun 9, 2009 01:12 AM
