Hello all, I have a 1972 F250 highboy with the 390fe. It has always ran great for me, aside from eating a distributor and I’ve taken it on multiple road trips.
I drove it for a good 3 hour drive today, got to my brother’s place and shut it off. I went to leave about an hour later and it was running quite poorly. I took my brothers truck, came back an hour after that and then it wouldn’t hardly even run. After fiddling with the carb, patching vacuum leaks, and adjusting the timing, nothing has helped. I’ll attach a video as to how she sounds, thanks for any help!
Have you done any work to the engine? I would check the timing chain to see if it jumped a tooth. Without tearing the front of the engine down you would need to pull the valve cover and set cylinder #1 valves to TDC, then see where the timing mark is.
When you adj the timing was the flash consistent indicating it was firing every time?
The thing must have fixed itself overnight because she started up and ran fine this morning. I think it could have been vapor lock from heat soaking after my long drive. Not sure, but I’ll keep it in mind and update here if things persist.
Along with the normal tune up issues
I see
Stuck valves, which sometimes means bent pushrods and broken valve springs creep up from time to time
How horribly does it run?
What ignition does it have?
Also look at your coil, it could be failing. If it starts running rough again, try cooling off the coil with cool water and see if it runs smooth then.
