6.2L V8 Discuss the 6.2L V8
Crank no start
Old May 14, 2026 | 05:29 PM
devo97's Avatar
devo97
1st Gear
Crank no start
I have a crank no start issue. Pulled the fuel pump and It bench tested fine. I have RCM trouble code B11D8-14 active. Circuit short to ground or open. I followed the diagnostic tree pinpoint test and everything is testing out fine. Replaced fuel pump module followed by the RCM as per the pinpoint test and have not gotten anywhere. Am very stuck and could use some help/suggestions.
As far as I understand the RCM is signaling the fuel pump module to cut fuel via the "event circuit" which depowers the fuel pump in the event of an accident.
Old May 15, 2026 | 05:40 AM
2015 F-350's Avatar
2015 F-350
What vehicle?
What year?
What engine?
What codes?
No signature so I have no idea if you are even in the right forum?
Having said that, I will assume you have a FORD truck with a 6.2L. The harness from the tank will have corrosion or an open that is interpreted as an open circuit due to airbag deployment, therefore turning off the fuel pump. Find the harness and the break or corrosion in the wire and you should be good.
But only if my assumption is correct about your vehicle. South Main Auto on YT had one just like this recently - might help you.
hermannm2
2009 - 2014 F150
Jun 17, 2024 01:20 PM
suburbanE450
1997 - 2003 F150
Jan 8, 2024 08:19 AM
stvMo
1997 - 2003 F150
Feb 26, 2023 06:23 AM
Bill Towne
Modular V8 (4.6L, 5.4L)
Jan 29, 2016 02:36 PM
makuloco2000
2004 - 2008 F150
Jan 16, 2014 12:00 AM
