Lamp socket advice
Old May 10, 2026 | 07:01 PM
dthut's Avatar
dthut
Lamp socket advice
79 f250, has a 76 grill and headlights if that makes a difference on the plug.
Hey guys looking for some advice here, my brake lights and signals randomly quit working. I still have headlights. Brake lights work when headlights are off, one goes out then one works. I’ve cleaned up the main ground at all lights to the body. I think it’s the connections inside the sockets, especially the little ground spring clip.
what is my quickest fix here, as I need my truck for work. It seems to be the rear lamp sockets that are in the worst shape and likley the culprit. I’m not even getting a blinking noise in the cab when signalling.
And or what is my long term option. I can’t seem to find the oem sockets online. Is there a simple modern conversion. I don’t mean LED or anything, I prefer the stock lights.
any advice would be so helpful! Cheers and thanks
Old May 10, 2026 | 07:54 PM
dthut's Avatar
dthut
Okay I ordered 4 Dorman sockets, looks like the rear signal/brakelight/running lights have the same socket as the front signal socket. Hoping that’s the case and also hoping this fixes me issue.
what would be the next culprit if this doesn’t fix it? Preparing myself
Old May 10, 2026 | 10:12 PM
440 sixpack's Avatar
440 sixpack
Very likely that will fix your problem, sockets are the most common problem with light issues.
If that doesn't do it the turn signal switch would be the next thing. it can mess up everything except the headlights.
Old May 11, 2026 | 09:03 PM
Vivian AUXITO's Avatar
Vivian AUXITO
PLATINUM SPONSOR
Hopefully the sockets take care of it. The old Ford light sockets love causing weird issues once they get crusty inside.
Honestly sounds like you're on the right track already. If it still acts up after that, I'd probably start looking at the turn signal switch like mentioned above.
Columbus1961
Oct 19, 2023 09:10 PM
Lawnview
2009 - 2014 F150
Dec 16, 2021 09:46 AM
pineapple13888
Sep 14, 2021 08:56 AM
Jenkins75
Jan 11, 2020 08:58 AM
loyal
Electrical Systems/Wiring
Feb 10, 2012 05:49 PM
