47 Ford truck hinges
Old May 9, 2026 | 08:12 PM
47ford truck's Avatar
47ford truck
4th Gear
Today I noticed that the hinges on my passenger door are super sloppy and the door is sagging. Has anyone replaced the hinges or know if the 1948 Ford truck hinges will work on the 1947?
Old May 9, 2026 | 09:00 PM
Rust Wrangler's Avatar
Rust Wrangler
Hinge pins are the same on the '48 hinges, but I believe the hinge bodies differ from the '42-'47 hinges. I'm not near my book, so can't confirm that.
Replacement hinge pins are available from several different sources.
Here is one source: https://bobdrake.com/collections/doo...-hinge-pin-set
Using the pin pusher tool makes the job fairly easy when the running boards are in place. If the boards are off, a drift will work to get the pins out. Oversize pins are also available if the hinges are badly worn. Good luck!
Old May 9, 2026 | 09:03 PM
47ford truck
4th Gear
Really wish it was just the pins but it seems like a weld possibly is bad on the door side. I am not sure how it is all held together besides the rivets. I can wiggle the door and see there is a gap between the door and where the hinge meets
Old May 10, 2026 | 09:17 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
https://www.jalopyjournal.com/forum/...oject.1307508/
It’s common I think to find the lower hinge area damaged on these early trucks. Above is a HAMB thread where a guy repaired the inner support for the hinge. Stu
gdp1701
Nov 27, 2024 04:29 PM
BKJJ
1947 and Older Ford Trucks
May 18, 2020 02:35 PM
FordPickup460
May 22, 2005 10:41 AM
sancochojoe
Apr 23, 2005 07:14 PM
taxidriver
Paint & Bodywork
May 14, 2004 12:00 PM
