Cmon Ford
Old May 3, 2026 | 12:49 PM
FishOnOne's Avatar
FishOnOne
Cmon Ford
And Jim Farley just recently got a big raise because of Fords quality metrics have improved....
Old May 3, 2026 | 02:51 PM
willynilly's Avatar
willynilly
being a long termer on this site you should know as well as anybody that fords rear ends went in the toilet basically 10yrs ago with the start of alumidooty. anybody paying attention surely took notice of all the rear end threads. i know i did
Old May 3, 2026 | 03:56 PM
Louisville Joe's Avatar
Louisville Joe
The old Sterling axle 10.5 axle seldom had issues and the 11.6 has not had too many, but some of those late Dana's are trouble, probably the biggest issue being the weak axle tubes. Lots of bearing failures too. AAM makes the best axles these days, hands down.
Old May 3, 2026 | 04:10 PM
Dustin F450's Avatar
Dustin F450
The rear ends are fine. The dealers aren't and truck owners are to lazy to crawl under and check the level, they just believe the clown show dealer...My Dana had TWO quarts in it when I took it home. Drive it around and blame the axle. Nope, dealer SUCKED, THE AXLE HAD IS DESIGNED WELL
Old May 3, 2026 | 04:40 PM
Louisville Joe
You are certainly right about low oil levels being an issue, but that doesn't explain the axle tubes being too thin. Tight U-bolts distorted the tubes and the spring perch welds would crack. Word is the issue was eventually fixed.
Old May 3, 2026 | 05:05 PM
FordExpy486's Avatar
FordExpy486
It seems like the Sterling 11.6 has taken over most Dana applications as of now in 2026 besides DRW. For a while Diesel Tremors were getting the Dana until Ford launched the 3.55 Sterling and it seems like most of those are coming with Sterlings now too. The Sterling seems pretty robust.
Old May 3, 2026 | 07:30 PM
Midwest87's Avatar
Midwest87
My alumaduty has a Dana 60 and 10.5. Both solid axles.
Ford offers models that have improved in quality. Weve listed them. If people wont listen to us, its not our problem. Axle issues are pretty much zero amongst our fleets. Any brand.
Old May 4, 2026 | 08:06 AM
FishOnOne's Avatar
FishOnOne
The Sterling 10.5 is about as reliable as an anvil and has a great reputation.
Old May 4, 2026 | 08:09 AM
FishOnOne's Avatar
FishOnOne
Shouldn't have to check fluid level in rear end. Farley's quality control should ensure it's correct from the factory.
Old May 4, 2026 | 10:20 AM
Rich1961's Avatar
Rich1961
It appears that every time he took his truck in the dealer said oh, we just got an update on that exact problem. Not saying Ford isn't at fault here but the dealers are not doing their due diligence when troubleshooting problems. I had a clutch fan lock up on my previous truck and had to argue with the dealer that it wasn't operating correctly. The Tech said normal operation for the clutch fan. BS! Finally had to take the service manager for a ride to convince him of the issue. Not the way things should be.
Old May 4, 2026 | 12:51 PM
HeatStroked's Avatar
HeatStroked
Got this in my email today from Ford;
We want to provide you with the latest update on your Super Duty Lariat® vehicle order. We’ve made great progress on your new Ford vehicle but have unfortunately experienced unexpected delays.
Rest assured, our team is diligently addressing these challenges to complete your vehicle as soon as possible. We genuinely appreciate your understanding and patience during this time and will continue to provide regular updates every step of the way.
Old May 4, 2026 | 01:46 PM
willynilly's Avatar
willynilly
aside from the 10.5 if you go back on this site and the tremor youll see enough people lost rear ends that it got my attention. sounds like your selective memory is switched on again.
Old May 4, 2026 | 02:45 PM
willynilly's Avatar
willynilly
most people are oblivious to this but fords on atleast its 4th (that we know about) revision of the 250/350 dana rear in only 10yrs . 2nd one was a complete disaster. 3rd one doesnt sound much better than the 2nd from the youtube vid i seen. 1st might be decent depending how many similarities is does or doesnt have to the 2nd. 4th could be the one people been losing bearings in (i would have to go back and check).
Old May 5, 2026 | 09:17 AM
FishOnOne's Avatar
FishOnOne
I agree the dealer plays an important role with resolving issues and going to bat for their customers. Some of these issues should not be trivial.
Old May 6, 2026 | 10:56 AM
B+ squad's Avatar
B+ squad
24 f250 @ 44k
Pinion seal leaked, fixed, now rear end has a gritty sound and a tuning fork tone between 35-50
My first 36k looked like this:
Trans leaked between engine/trans @ 2k
Blower motor noisy @ 2k
AC condenser leaked @ 18k
Fan cowling hitting engine fan @18 k
Steering shaft clunking @ 35k
P-side hub went out @35 k
Valve body due to incredibly hard P-R-D shifts @35 k
Weather stripping that squeaked terrible @ 2 k
Windshield cracked in a 3' smile shape @ 1k
"That's normal" according to dealership:
Cold start sounds like leaking exhaust
Valves clatter something terrible
HVAC makes a "honk" noise with defrost
Rattle in the door they can't seem to replicate
Oh, the 4/5 shift feels like the transmission shift gets stuck and acts like a manual when shifting...i.e. power cuts
It's been a great truck other than that.
