Coil Spring Choices, Daunting?
Old May 26, 2026 | 09:27 AM
maples01's Avatar
maples01
Camber will mess with bump steer, get that corrected first, of coarse the height you have makes like a sail, have you upgraded the sway bars on it with the heavier ones?
Old May 27, 2026 | 09:57 AM
OCBlue88's Avatar
OCBlue88
No upgrade on the sway bars. Just the stock front. I've taken in on a twisty mountain road and it feels good there. I'm sure a rear sway bar would help also, but at the speeds I'm going at it doesn't feel like it needs it because it feels controlled. The steering appears to have 4 turns lock to lock. That's the part that feels like it's holding back my cornering speeds especially on tight curves. Something else I find useful on this Van with its C6 is the engine braking. Very nice to have on long descends on twisty roads. On a lot of these modern trucks with many gears, they all feel like they don't have much engine braking, especially turbocharged ones. So when you're descending down a mountain pass it just wants to gain speed even when you downshift a gear, or two. With the C6 even in 3rd gear, as long as OD is locked out, it will provide enough engine braking. Makes for a more relaxing drive.
Old May 27, 2026 | 04:54 PM
maples01's Avatar
maples01
The front looks like its sitting low, its lower than my 99 E350 sat, you might have king pins, the ball joints have camber adjustments, king pin requires the I-bean to be bent, big semi truck garages can do that, but you'll need to be sure.
Old May 27, 2026 | 05:08 PM
OCBlue88's Avatar
OCBlue88
Yeah her *** is high. She's completely empty still. Once I add water, food, should be close to level.
Needs to have a Camber Adjustment shim installed on the upper ball joint. Have to find an alignment shop who can do that. The shop who did the alignment said they never heard of the camber shims and instead suggested I get the I-Beams bent. I'm not going to do that when Camber shims are so much less effort to do.
Old May 27, 2026 | 05:17 PM
maples01's Avatar
maples01
They suck at their job, obviously aren't up to date on training for that job.
Old May 28, 2026 | 09:52 AM
OCBlue88's Avatar
OCBlue88
Yes very disappointed with their response especially since they got highly recommended for Commercial Vehicle work and they work on Econolines all the time. They sell the Camber bolt Shims in Autozone for goodness sake! So it's not something unusual.
speakerfritz
6.7L Power Stroke Diesel
Jul 23, 2022 11:18 AM
speakerfritz
Jul 11, 2022 08:43 AM
JAE88
6.2L V8
Oct 27, 2013 05:51 AM
rollinblackcloud
Offroad & 4x4
Feb 7, 2012 02:02 PM
doom899
Sep 9, 2008 10:37 PM
